/lib/udev/rules.d for imx6 sabresd board for establishing network for usb modem
bandarulavanya
Contributor V
Hi All,
I am trying to use the usb modem to my board, i can able to do usb_mode switch to convert from CD-ROM to modem.
LOG for this
I connected modem to usb host :
usb 1-1: new high speed USB device number 2 using fsl-ehci
usb 1-1: New USB device found, idVendor=1bbb, idProduct=f000
usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1: Product: MobileBroadBand
usb 1-1: Manufacturer: Alcatel
usb 1-1: SerialNumber: 0123456789ABCDEF
Convertion using usb_modeswicth:
usb_modeswitch -v 0x1bbb -p 0xf000 -V 0x1bbb -P 0x0017 -M "55534243123456788000000080000606f50402527000000000000000000000"
Looking for target devices ...
No devices in target mode or class found
Looking for default dusb 1-1: usbfs: process 2226 (usb_modeswitch) did not claim interface 0 before use
evices ...
Found devices in default mode, class or configuration (1)
Accessing device 002 on bus 001 ...
Getting the current device configuration ...
OK, got current device configuration (1)
Using endpoints 0x01 (out) and 0x81 (in)
Inquiring device details; driver will be detached ...
Looking for active driver ...
No driver found. Either detached before or never attached
SCSI inquiry data (for identification)
  Vendor String: ONETOUCH
   Model String: KINGFISHER
Revision String: 2.31
USB description data (for identification)
  Serial No.: 0123456789ABCDEF
Setting up communication with interface 0
Using endpoint 0x01 for message sending ...
Trying to send message 1 to endpoint 0x01 ...
OK, message successfully sent
Resetting response endpoint 0x81
Resetting message endpoint 0x01
usb 1-1: USB disconnect, device number 2
Device is gone, skipping any further commands
-> Run lsusb to note any changes. Bye.
root@(none) ~$ usb 1-1: new high speed USB device number 3 using fsl-ehci
usb 1-1: New USB device found, idVendor=1bbb, idProduct=0195
Now i am inserting the modules :
insmod usbnet.ko
insmod usb-storage.ko
insmod cdc_ether.ko
insmod  rndis_host.ko
insmod usbserial.ko
Log is here:
                                  insmod usbnet.ko
root@(none) /home$ insmod usb-storage.ko
Initializing USB Mass Storage driver...
scsi0 : usb-storage 1-1:1.2
USB Mass Storage support registered.
root@(none) /home$ scsi 0:0:0:0: Direct-Access     ONETOUCH KINGFISHER       2.31 PQ: 0 ANSI: 2
scsi 0:0:0:0: Attached scsi generic sg0 type 0
insmod cdc_ether.ko
usbcore: registered new interface driver cdc_ether
root@(none) /home$ insmod rndis_host.ko
rndis_host 1-1:1.0: eth0: register 'rndis_host' at usb-fsl-ehci.0-1, RNDIS device, 08:2e:5f:29:0e:69
usbcore: registered new interface driver rndis_host
root@(none) /home$ insmod usbserial.ko
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
Now if i give ifconfig :
root@(none) /home$ ifconfig -a
eth0      Link encap:Ethernet  HWaddr 08:2E:5F:29:0E:69
          BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          LOOPBACK  MTU:16436  Metric:1
          collisions:0 txqueuelen:0
How we can establish the connection?
In my PC(kernel version -3.2.0-91-generic-pae ) i tried it by disabling automatic usb_modeswitch in usb_modeswitch.conf file in /etc folder.
i did
sudo usb_modeswitch -v 0x1bbb -p 0xf000 -V 0x1bbb -P 0x0017 -M "55534243123456788000000080000606f50402527000000000000000000000"
after this immediately it is converting to modem and connection is establishing.
Looking for default devices ...
   found matching product ID
   adding device
Found device in default mode, class or configuration (1)
Accessing device 008 on bus 001 ...
Using first interface: 0x00
OK, driver found ("usb-storage")
OK, driver "usb-storage" detached
Dmesg:
[10449.492021] usb 1-6: new high-speed USB device number 9 using ehci_hcd
[10449.661393] rndis_host 1-6:1.0: eth1: register 'rndis_host' at usb-0000:00:1d.7-6, RNDIS device, 08:2e:5f:29:0e:69
[10449.662012] scsi7 : usb-storage 1-6:1.2
[10450.680042] scsi 7:0:0:0: Direct-Access     ONETOUCH KINGFISHER       2.31 PQ: 0 ANSI: 2
[10450.680783] sd 7:0:0:0: Attached scsi generic sg1 type 0
[10450.708634] sd 7:0:0:0: [sdb] Attached SCSI removable disk
[10459.872009] eth1: no IPv6 routers present
and connection is establishing .
similar to this can we get in board also ?
can i get udev/rules.d  and supported files for imx6 sabresd board ?
Thanks & Regards,
Lavanya
bandarulavanya
Contributor V
Hi  Lavanya,
After creating eth0 node do " ifconfig eth0 proper-IP up " or try with
" udhcpc -i eth0 -b -t 10"
then you will get the IP and then "ping google.com"  or global ip like 192.168.1.1
Thanks & Regards,
lavanya
Hi Bandaru
seems driver for this device is not correct or from other linux
distribution/version. It may be suggested to ask from vendor of this
usb modem updated driver for specific linux version which is used in the case.
bandarulavanya
Contributor V
Hi igorpadykov,
Actually i am asking about this connection of networking is happening automatically bcz of udev/rules.d in PC that how we can do and what is the exact config file they are using.
For usb_modeswitch they are using "40-usb_modeswitch.rules" similarly which file they are using for setting network connection.
Thanks & Regards,
Lavanya
bandarulavanya
Contributor V
Hi  Lavanya,
Thanks & Regards,
lavanya
