Hello Everybody,
I have a very strange issue with obtaining CodeWarrior floating license. Everything works fine on a local network. Unfortunately when I have the laptop on a slow network (WiFi or VPN) I can obtain the floating license very rarely (1 from 10 tries). The error is below:
No valid license key was found for this installation of CodeWarrior Development Studio. Please register your product by following the instructions on the registration card or by contacting license@freescale.com.
Cannot connect to license server
The server (lmgrd) has not been started yet, or
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature: Win32_CWIDE_Limited
Server name: SRVV-LIC01-PRG
License path: C:\Program Files (x86)\Freescale\CodeWarrior for ColdFire -
V7.1\license.dat
FLEXlm error: -15,570
For further information, refer to the FLEXlm End User Manual,
available at "www.macrovision.com".
I have already tried:
Any thoughts?
Thank you.
Solved! Go to Solution.
Can you refer to the doc:
How to install/check if my floating license file is running ? (known issues)
Following the problem you meet I recommend you to use the port-daemon@host.
Pascal
NXP Technical Support
Pascal
