MX233 BATTERY CURRENT_NOW ISSUE
paolomartinetti
Hi everybody,
i have an imx233 device equipped, running 2.6.31 kernel, powered by Li-Ion battery.
When i watch actual current in /sys/class/power_supply/battery/current_now file I always see 0.
Why? Is it a bug? If so, could you suggest some patch to me?
Thanks in advance
Paolo
jamesbone
Hello Paolo,
Are you using an EVK board to made this test? or how it is implemented the battery connection?
have you try with
/sys/class/power_supply/battery/batt_current
Jaime
