LS2085Ardb: Downloading u-boot using Codewarrior cwtap
ramasubramanian
Do you have any guide describing the steps on how to download a custom built u-boot to LS2085Ardb using codewarrior cwtap?
Please point us to relevant application note for bringup of 2085A based custom board
Rams
marius_grigoras
Please use our last CodeWarrior for ARMv8 (2016.01 - 11.2.0) and make next steps:
1. open it using fsl_eclipse.bat from CW_ARMv8
2. make a new TCC configuration and use the Connect button
3. after connecting to the board, just use the Flash Programmer button
Thank you,
Marius
ramasubramanian
I am using CodeWarrior Development Studio for QorIQ LS series - ARM V8 ISA Version: 11.1.1.  I am unable to get connect button in TCC configuration.  Do you recommend to install CodeWarrior for ARMv8 (2016.01 - 11.2.0)?
Rams
marius_grigoras
Hi Rams,
To be honest I recommend 11.2.0 (our last release) because it has also Flash Programmer GUI support.
If you want to continue with 11.1.1 please read in the Targeting Manual (from CW_ARMv8\ARMv8\Help\PDF) in chapter 7, how to use FP from gdb cmd line (don't scary, it's pretty easy are there are only 3 steps you need to do).
Marius
ramasubramanian
Hi Marius,
Thanks.  We now downloaded 11.2.0. We will test and let you know if we have any problems.
Rams
