CodeWarrior V7.0 (IDE 5.9.0) MCF54450 device initialization
M_H_
I'm trying to initialize the MCF54450 using the Device Initialization option. The code it generates (C) has the values written to the registers in decimal. I'm sure I came across a way to set this to default to hexadecimal but now I can't find it. Does anybody know how to make hexadecimal the default with Device Initialization? It is much easier to see what is going on if these values are hexadecimal. Thanks.
M_H_
Found it.
It may not be the correct way of doing it but it worked. I opened my project's .iPE file and found the following
HighNumberFormat=DEC
AsmAddrFormat=DEC
AsmDataFormat=DEC
AsmBitsFormat=DEC
and changed it to
HighNumberFormat=HEX
AsmAddrFormat=HEX
AsmDataFormat=HEX
AsmBitsFormat=HEX
and now it generates hex numbers. With Processor Expert open I could find these under options but I couldn't find an equivalent when using Device Initialization. I'm sure there must be a better way than editting the .iPE file so if anyone knows it I'm still interested to find out.
Message Edited by M.H. on 2008-02-15 02:11 PM
