How to use I2C with MC9S12ZVC?
seung-taeryu
Could you provide the I2C sample code for MC9S12ZVC?
RadekS
Hi Seung-Tae,
I prepared for you simple example code for read Humidity and Temperature data from STH21 sensor at VLG-MC9S12ZVC board.
Unfortunately I don’t have this board here, therefore I cannot test it now.
Please use it as unfinished and untested version just for your inspiration.
I hope it helps you.
RadekS
seung-taeryu
Thnak you for kindly answer.
catonia
Hello Seung-Tae,
did you have that code working ?
I downloaded the example but it is not working on my evaluation board.
Did you have to modify anything ?
thanks a lot,
