downloade fsl-arm-yocto-bsp
liaoran
    I now use yocto. And I use the command "$ repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-3.14.28-1.0.0_ga" to download fsl-arm-yocto-bsp. Last time I can use it successfull, but now it is fail to connect! How can I solve this problem? thank you very much.
art
Most likely, this is some temporary problem with the server. Try again later.
Artur
