i am new o embedded design field, i need to use code worrior 10.5 for my controller SPC560D40L1 series which is from STmicroelectronics.
i have freescales "MCU_Power_Architecture" compiler manual with me. some of the compiler options mentioned in that compiler manual are specific to freescale controllers. which are not correct for STmicro....
Please help me with the compiler options or compiler manual which will be suitable for STmicro....
Solved! Go to Solution.
Hello Shivananda
SPC560D40L1 should have the same CPU e200z0h and other specifications with our MPC5602D.
So our compiler in CodeWarrior for Qorivva should also support SPC560D40L1.
Best Regards
Fiona Kuang
Technical Information & Commercial Support
Hello Shivananda
Best Regards
Fiona Kuang
