There are 3 different styles mentioned in the datasheet regarding package and pinout of the device. Depending on which style you have, determines the electrical connections. How do I know which style I have?
Hi Steve,
Style 1 is the correct one for the MPX2100D. The other styles are incorrect and will be removed in the next revision of the datasheet.
1 – GND
2 – +Vout
3 – Vs
4 – -Vout
Tomas
Hello Steve,
In this case I recommend the following post:
Different pin styles in pressure sensors documentation.
I hope this material will be useful for you.
If I misunderstood your question, feel free to let me know. I will be glad to help.
Have a great day.
David Diaz.
What about style 3?
