I'm using the MKL26Z256 (64 pin), and have to make an ad-conversion on ad-channel 4b(pin 17) but I can't make it work.
when trying, i get a value from ad-channel 4a(pin 10). where do I select if I'm using adc-4a or adc-4b?
br Lindy
Solved! Go to Solution.
Yep, found the solution:
ADC16_DRV_SetChnMux(ADC16_INSTANCE, kAdc16ChnMuxOfB);
