I need an example startup code in assembly for KEA-128. I am using CodeWarrior IDE.
Hi Santiago,
I want the startup code to be in assembly language.If you change it as assembly in the wizard only the main file changes into assembly language.Please let me know how to change the startup code in assembly language(like __arm_start.c, __arm_end.c files etc).
Thank you Santiago.Can you tell me how to do that ?Is there any application note or any documents or videos on how to create assembly language Startup code in KEA-128
