I am currently working on the LS1021a-iot board.I am trying to partition the QSPI NOR Flash.I have edited the dts file but the partition is not getting created(/proc/mtd shown empty).Is there any other file i need to modify?Please help me to solve the problem.
Thanks in advance.
Solved! Go to Solution.
1.I edited the driver for quad spi (fsl-quadspi.c).The driver was always returning data of device type vybrid.I made necessary modification so that it returned the LS1021a's data.Here is the modification.
.devtype = FSL_QUADSPI_LS1(instead of FSL_QUADSPI_VYBRID)
2.Edited the dts and made necessary modifications for qspi.We had two qspi chips on the board.dts is given below.
&qspi {
num-cs = <2>;
bus-num = <0>;
fsl,spi-num-chipselects = <2>;
fsl,spi-flash-chipselects = <0>;
fsl,qspi-has-second-chip;
status = "okay";
qflash0: s25fl512s@0 {
#address-cells = <1>;
#size-cells = <1>;
compatible = "spansion,s25fl512s";
spi-max-frequency = <20000000>;
reg = <0>;
partition@0 {
label = "Filesystem";
reg = <0x200000 0x28000000>;
partition@1 {
label = "DTB";
reg = <0x2A00000 0x100000>;
partition@2{
label = "Kernel";
reg = <0x2B00000 0x500000>;
partition@3{
label = "Free-space";
reg = <0x3000000 0x1000000>;
qflash1: s25fl512s@1 {
#size-cells = <1>;
reg = <1>;
partition@0 {
label = "NOR-Second64";
reg = <0x0 0x4000000>;
Now the qspi is listed in /dev/mtd showing all the partitions.It worked!!!!!
&qspi {
num-cs = <2>;
bus-num = <0>;
status = "okay";
#size-cells = <1>;
reg = <0>;
partition@0 {
partition@1 {
label = "DTB";
partition@2{
label = "Kernel";
partition@3{
#size-cells = <1>;
reg = <1>;
partition@0 {
