I am getting a loss of clock status. The processor resets with the "LOCS" bit set. It occurs intermittently. The ICG clock module is configured as follows:
ICG Conrol register (ICGC1) 1111000
- HGO set for high gain oscillator HGO =1
- Range set for high frequency range RANGE = 1
- REFS set for oscillator using crystal REFS = 1
- CLKS mode FBE (FLL bypassed, external reference) CLKS = 10
The external oscillator is a 2 mhz crystal, MCLK = 250khz
Anyone have any ideas why I'm getting the intermittent reset?
Hi Kevin
do your product is on a noise environment?
Please check the following application note AN3208
Would be possible that you send me your schematics?
Vicente Gomez
