I have a problem about the MQX task scheduling
wyflsxy
hello all,
I  used KDS3.0 and based on MQX4.2 and KSDK1.2 project, my board is twrk64f120m,
the task scheduling to me have a little bit of problem
I have add the TCPIP  tasks and it was worked ok before,
But when I add the CAN bus  program to initialization,
it looks like that the task is blocked in lwsem.c as below
could you know what's the problem?
        sem_chk_ptr = (LWSEM_STRUCT_PTR) ((void *) kernel_data->LWSEM.NEXT);
        while (sem_chk_ptr != (LWSEM_STRUCT_PTR) ((void *) &kernel_data->LWSEM))
            if (sem_chk_ptr == sem_ptr)
                /* remove semaphore from kernel LWSEM queue */
                _QUEUE_REMOVE(&kernel_data->LWSEM, sem_ptr);
                break;
            } /* Endif */
            sem_chk_ptr = (LWSEM_STRUCT_PTR) ((void *) sem_chk_ptr->NEXT);
        } /* Endwhile */
danielchen
I guess there is a lwsem  conflict, this lwsem is shared between your can task and tcpip task
wyflsxy
but I don't have a lwsem shared between and can
I only used lwsem between tcpip init and tcpip send
