Hi guys.
I am trying to debug a KSDK example application on mi FRDM-K64F, but after building the platform library and the application, I get this error when I try to debug it:
Error in services launch sequence
Launching command [C:\Freescale\KDS_3.0.0\eclipse\../openocd/bin/openocd -c gdb_port 3333 -c telnet_port 4444 -f kinetis.cfg -c echo "Started by GNU ARM Eclipse"] failed.
Cannot run program "C:\Freescale\KDS_3.0.0\eclipse\../openocd/bin/openocd": Launching failed
I tried to find openocd executable under eclipse subfolder but I think it is missing
Any idea?
Hi David.
Yes I was using KSDK 1.2. Now It is updated to 1.3.
I copied your openocd folder to KDS directory and now it is working.
Thanks !!!
Hi Jose,
What version of KSDK are you using? If KSDK_1.2 please upgrade to latest KSDK_1.3 on web at http://www.freescale.com/ksdk .
I'm attaching my openocd folder that should be in your KDS_3.0.0 folder.
David
