Write HEX to LCD
Write HEX to LCD
mariaotero
Hello, i'm kinda new in all this world. So, i'm trying to display like decimal an hexadecimal value into a LCD 16x2 display.
I know the i need to write it in ASCII, but my problem is the i can't figure it out how to split that value into 4 or 5 bytes, for example:
0x270F = 0x39 0x39 0x39 0x39 (9999)
0xFFFF = 0x36 0x35 0x35 0x33 0x35 (65535).
Don't even know how to search for what i'm looking . Some guidance would be useful.
Thank you . (sorry for my bad english not my native language
PD: Working with S08AW32 Relocatable ASM in CodeWarrior 10.2
Tags (3)
mariaotero
This is how i solved, any advice or critic would be nice :smileyhappy:.
DataRAM DS 2
Centena ds 1
Decena ds 1
Unidad ds 1
Stack ds 1
;DataRAM = Any value between 0 and 999
LDHX DataRAM
CPHX #100
BLO MENOR
BHI MAYOR
MENOR LDA DataRAM+1
LDHX #10
DIV
STA Decena
ldhx           #10
MUL
ldhx           DataRAM
JSR srAIXdc
stx          Unidad
Jsr srBCD
RTS
MAYOR            CPHX #255
BHI MAYOR2
LDA DataRAM+1
LDHX #100
DIV
rtMY1 STA Centena
LDHX #100
MUL
LDHX DataRAM
jsr srAIXct
STX Stack
LDA Stack
LDHX #10
DIV
STA Decena
ldhx           #10
MUL
ldx          Stack
JSR srAIXdc
stx          Unidad
Jsr srBCD
RTS
MAYOR2 LDA DataRAM+1
LDHX DataRAM+0
LDX #100
DIV
JMP rtMY1
;*************SubRoutines*************
srAIXct:           LDA Centena
lpAIct aix #-100
deca
cmp #0
bne lpAIct
RTS
srAIXdc:           LDA Decena
lpAIdc aix #-10
deca
cmp #0
bne lpAIdc
RTS
srBCD: LDA #$89
JSR LCDi
LDA Centena
ADD #$30
JSR LCDw
LDA Decena
ADD #$30
JSR LCDw
LDA Unidad
ADD #$30
JSR LCDw
RTS
mariaotero
DataRAM DS 2
Centena ds 1
Decena ds 1
Unidad ds 1
Stack ds 1
LDHX DataRAM
CPHX #100
BLO MENOR
BHI MAYOR
MENOR LDA DataRAM+1
LDHX #10
DIV
STA Decena
ldhx           #10
MUL
ldhx           DataRAM
JSR srAIXdc
stx          Unidad
Jsr srBCD
RTS
MAYOR            CPHX #255
BHI MAYOR2
LDA DataRAM+1
LDHX #100
DIV
rtMY1 STA Centena
LDHX #100
MUL
LDHX DataRAM
jsr srAIXct
STX Stack
LDA Stack
LDHX #10
DIV
STA Decena
ldhx           #10
MUL
ldx          Stack
JSR srAIXdc
stx          Unidad
Jsr srBCD
RTS
LDHX DataRAM+0
LDX #100
DIV
JMP rtMY1
lpAIct aix #-100
deca
cmp #0
bne lpAIct
RTS
srAIXdc:           LDA Decena
lpAIdc aix #-10
deca
cmp #0
bne lpAIdc
RTS
srBCD: LDA #$89
JSR LCDi
LDA Centena
ADD #$30
JSR LCDw
LDA Decena
ADD #$30
JSR LCDw
LDA Unidad
ADD #$30
JSR LCDw
RTS
mariaotero
Sorry for not saying, but i don't know C. I can read it, but i can't code in that language.
Okay, i will try to make a project with C and ASM to see if i can debug it, to get the ASM code.
Any idea of how can i search for what i'm looking?
Thank you for the answers :smileyhappy:.
ZhangJennie
I am not assembly code expert, but if use C, we can implement the code this way: thus D0,D1,D2,D3 is 9,9,9,9. can it help you?
int ASCII(int data)
void main(void) {
volatile  int data=0x270F;
volatile  int D0,D1,D2,D3;
D0 = ASCII(data%10);
D1 = ASCII((data%100-data%10)/10);
D2 = ASCII((data%1000-data%100)/100);
D3 = ASCII((data%10000-data%1000)/1000);
int ASCII(int data) {
if ( (data<=9) && (data>=0))
   return (data + '0');
else
   return 1;
Zhang Jun
StenS
The easiest (but absolutely not the most efficient) way is to use the sprintf-function:
char buff[6];
unsigned int num;
sprintf(buff, "%u", num);
After this the number will be as a null-terminated string (1..5 characters plus the terminating \0) in buff. By adding formating specifications you can affect how the number is converted.
Sten
