hi supporter
with the command "make otapackage", we build fail.
Install system fs image: out/et1D_em70/target/product/partner/system_sparse.img
out/et1D_em70/target/product/partner/system_sparse.img+out/et1D_em70/target/product/partner/obj/PACKAGING/recovery_patch_intermediates/recovery_from_boot.p maxsize=385389312 blocksize=4224 total=307524476 reserve=3894528
if [ true = true ]; then \
simg2img out/et1D_em70/target/product/partner/system_sparse.img out/et1D_em70/target/product/partner/system.img; \
fi
APK certs list: out/et1D_em70/target/product/partner/obj/PACKAGING/apkcerts_intermediates/em70_debug-apkcerts-20150518.txt
# In case value of PACKAGES is empty.
Import includes file: out/et1D_em70/host/linux-x86/obj32/EXECUTABLES/fs_config_intermediates/import_includes
host C: fs_config <= build/tools/fs_config/fs_config.c
Export includes file: build/tools/fs_config/Android.mk -- out/et1D_em70/host/linux-x86/obj32/EXECUTABLES/fs_config_intermediates/export_includes
host Executable: fs_config (out/et1D_em70/host/linux-x86/obj32/EXECUTABLES/fs_config_intermediates/fs_config)
Install: out/et1D_em70/host/linux-x86/bin/fs_config
Package target files: out/et1D_em70/target/product/partner/obj/PACKAGING/target_files_intermediates/em70_debug-target_files-20150518.zip
building image from target_files RECOVERY...
building image from target_files BOOT...
Traceback (most recent call last):
File "./build/tools/releasetools/make_recovery_patch", line 53, in <module>
main(sys.argv[1:])
File "./build/tools/releasetools/make_recovery_patch", line 49, in main
common.MakeRecoveryPatch(input_dir, output_sink, recovery_img, boot_img)
File "/home/adil/em70/imx6lp/build/tools/releasetools/common.py", line 1159, in MakeRecoveryPatch
td_pair = GetTypeAndDevice("/boot", info_dict)
File "/home/adil/em70/imx6lp/build/tools/releasetools/common.py", line 1110, in GetTypeAndDevice
return PARTITION_TYPES[fstab[mount_point].fs_type], fstab[mount_point].device
KeyError: '/boot'
make[1]: *** [out/et1D_em70/target/product/partner/obj/PACKAGING/target_files_intermediates/em70_debug-target_files-20150518.zip] Error 1
make[1]: Leaving directory `/home/adil/em70/imx6lp'
cp: cannot stat `out/et1D_em70/target/product/partner/em70_debug-ota-20150518.zip': No such file or directory
make: *** [otapackage] Error 1
#### make failed to build some targets (01:27:03 (hh:mm:ss)) ####
Solved! Go to Solution.
Hello Xingrui Zhu,
Are you still having this issue? Would you please provide more details on theAndroid BSP version you are using and for which board? Please mention the steps you ran on the Android User’s Guide in order to see where the problem may reside.
Hello Xingrui Zhu,
