KDS3.0 Export
KDS3.0 Export
shauldorf
Contributor V
Using KDS3.0 Export project generates large archive file.
What must be included in the Filter Types to reduce size but to be able to import it on other PC?
Shaul
shauldorf
Contributor V
Hello Erich
As usual it was helpful
Shaul
BlackNight
The same rules apply as for using a version control system (see KDS and Version Control ). Basically you do not need to expert the generated files.
So the 'Debug' folder you do not need for sure.
I hope this helps,
Erich
