LCD via Flexbus for k70
ankurchauhan
I'm trying to use Twr-LCD Module via flexbus interface using  k70 bareboard project.
can anyone share some sample code and datasheets for this.
Ankur
adriancano
Hi Ankur Chauhan,
You will probably find useful this post:
FlexBus in 16 bit mode and 8 bit access
Adrian
ankurchauhan
Thanks Adrian..
ankurchauhan
Hi Adrian:
As per the sample code given in the link, they are sending some command to some particular address (i.e some hex values like 0x004f to address 0x60000000 address is always fix but values varying ) can u explain me whats those command are doing.
Ankur
