Hi , we have purchased CWA-LS-DVLPR-FL which is annual license. I understand that after one year this license will stop and we will not be able to use Codewarrior, correct? But somehwere I heard about the possibility to quarantine the license, e.g. if we know that during summer nobody will work on the project we put the license in quarantine and with this we prolong the license activated, is this possible, could you please confirm?
Hello marek martinkovic,
I am not aware of a way for that. May be what you heard is exceptional case, if that is true, it should be handled by special tool by the license team, common technical support would not be able to do that. Maybe you could submit SR to license team to check if it would be exceptional to you.
But at least you could request the evaluation license after your one year expired, the evaluation license is 30 days.
Lunmin
