HI:
MPC5644C serial baud rate can be achieved? Is there 10M(TTL)? Thank you. !
Hi Jack,
if you use system clock 120MHz then theoretical maximal baud rate is 7,5 Mb/s according this calculation:
baud rate = fsys / (16 * prescaler)
baud rate = 120 000 000 / 16 = 7,5Mb/s.
But you have to remember parasitic effects of the bus and potential error between transmitter and reciever.
Martin
Hi martinkohler,
Thanks.
