MC9S08QE32 I2C problem with Tmp112
gpd
I'm tring to read temperature from Tmp112 sensor connected to my MC9S08QE32 via I2C bus.
I've generated the code with Processor Expert, but I never receive the ack condition, so I always read ZERO.
Is possible to see some I2C (Processor Expert) working code? Just as example.
Thank you.
ZhangJennie
Hello Gain,
I attached you a processor expert I2C demo code made under CW6.3. you can also get it from
{CW6.3 install}\ProcessorExpert\Projects\Test projects\InternalI2C.
Zhang Jun
gpd
Hi Zhang,
I can't see the attached.
ZhangJennie
I just attached it.
can it help?
Zhang Jun
