Which is default values of all registers of the MMPF0100F0AEP? I can't find a place that states the defaults. I'm interested more specifically on PWRON_CFG register. The F0 part is PWRON_CFG=0 or PWRON_CFG=1?
Leonardo
Hi Leonardo,
All default values of registers in MMPF0100F0AEP are listed in datasheet of MMPF1000. check it , please!
weidong
The register PWRON_CFG in datasheet is marked with X, this means that devices can have any value in this register from factory? Probably no, Which is the default value for F0 parts? Maybe I looking for the information at wrong place.
