I noticed that one can build piglit in imx-3.10.53-1.1.0_ga yocto build.
The sanity test is failing on iMX6.
According to README, these tests should pass to be able to rely on the testsuite results.
however, unfortunately "readPixSanity" test is failing on iMX6.
Can someone help me to fix it?
I have attached the log.
Thanks & Regards,
Parag
Original Attachment has been moved to: main.zip
Has anybody tested piglit on iMX6? Is it supposed to work?
Thanks & Regards,
Parag
Hi Parag,
I have not tested piglit on my side, but there is a disccussion in openembedded community about how to make the tests run, i guess this migth be helpful:
[meta-fsl-arm] piglit: Add Vivante GPU support - Patchwork
Hi Alfred,
Thanks for the answer.
I am able to run the tests. But many of them are failing.
And even sanity tests are failing.
Parag
