Hi igorpadykov
Thank you!
Linux driver, what do you use? GenericPHY?
Hi igorpadykov
Thank you!
But.. 10Base-T hulf ping test faild in my custom i.mx6Q board.
I was examined.
I had good result in the setting below.
Register 18[14bit] 10BT HD Loopback Disable = 1 (Disable).
1. i.MX6 unsupported "10base-T hulf loopback" ?
2. i.MX6 need Loopback mode disable in PHY?
I believe yes, however better if you would consult with
phy datasheet.
Hi 翔太 阿部
yes, this transceiver has 2.5V I/O supply
and i.MX6 supports RGMII 2.5 V mode.
