KDS-3.0, KSDK-1.2.0
I wonder which include files are intended for application programmers. Is there any rule to use?
Today I want to use 'shell.h' which is located in 3 places:
1. rtos\mqx\lib\frdmk64f.kds\debug
2. rtos\mqx\nshell\source
3. utilities
Hello Ole Asbjorn Fadum,
in shell.h located at \utilities\shell\ you set general settings.
in shell.h located at \rtos\mqx\nshell\source\include\ you set MQX RTOS nShell.
Iva
And which one should my project include?
Hello Ole,
please, modify files in this folder. It depends what do you exactly want to modify if you need to add command, change command behavior etc...
I hope this helps,
Best Regards
Iva
