Hello Champs,
When we don't use internal RTC in i.MX50, do we still need to provide NVCC_SRTC?
My customer says without NRCC_SRTC, 32.768KHz clock doesn't ocsilate...
Nori Shinozaki
Solved! Go to Solution.
Hello, Shinozaki,
Your customer's right, you need to provide NVCC_RTC even if you don't use RTC, because internal circuit of 32.768K clock will use this voltage.
Weidong
Hello, Shinozaki,
Weidong
Weidong,
Thanks for the quick answer!
Nori Shinozaki
