Inbox AND Firefox
Inbox AND Firefox
oaf
Today the entry to the inbox is NOT available when using Firefox (This entry is written via IE)
oaf
Yes, I've tried your suggestion. The suggestion was good, and I can inform you that the culprit is Ghostery V-5.4.5.1 :smileydevil:
I've added the freescale community as an exception to Ghostery and now Firefox is working
(This replay is done from it).
Thx
admin
Specialist II
Hi, can you please provide a screenshot of the error message you get in Firefox?
oaf
Inbox.jpgHi,
Enclosed is a screendump when I press the down-arrow beside the blue circle.
I'm using Firefox 37.0.2
oaf
The start page differs too:
admin
Specialist II
So, you are not seeing any options after clicking on the arrow?
oaf
1. That's correct, pressing the down-arrow doesn't do anything (except making the background a little bit darker, but this is because of the shift of focus)
2. 2nd problem is that the selection for i.MX, Kinetis... is NOT visible when browsing with Firefox...
admin
Specialist II
Thanks for the detail, let me contact the support team and get back to you.
Plus, can you please let me know your PC's operating system? Or are you accessing from a Tablet or Mobile device?
admin
Specialist II
Also, can you try deleting your cache from Firefox browser and try again?
Besides that, let me know if you can access the menu using other browsers such as Chrome, Safari or IE.
oaf
I'm running Win7-64. I don't have any additional browser except FireFox.
FireFox doesn't work (tried just now)
IE works.... :smileysad:
admin
Specialist II
Hi, it seems like you have Java script disabled.
1.- Go to Firefox browser and type about:config
2.- Press I'll be careful, I promise
3.- Search for javascript.enabled and ensure that is set to true
oaf
Ok, javascript.enabled was enabled, and yes I've checked my Firefox doesn't work today (either)
admin
Specialist II
Do you see any errors in the browser's javascript console when you click the button?
This is how you access the console:
1.- Right Click in the community page
2.- Click on "Inspect Element (Q)"
3.- Make sure you selected the "Console" tab and the "JS" output.
4.- Please share the console errors you get
oaf
The console is absolute blank, also the coloumn with 'i.MX','Kinetis'... is NOT presentJavaConsole.jpg
admin
Specialist II
Hi, I was wondering if you can join a webex call tomorrow. We’ll be meeting with the verdor.
10am CST – 10:30am CST
OR
11amCST – 11:30am CST
Please confirm.
oaf
Sorry, I was in meetings all day. I have a little problem with scheduling a webex meeting, but I could do kind of dump/experiment if you tell me what to do....
admin
Specialist II
Hi, I was wondering if you had been able to fix the issue and access the community from Firefox?
oaf
Thx
admin
Specialist II
Awesome! :smileyhappy:
admin
Specialist II
Go to Firefox menu, located at the top right and select Add-ons
Click on the Extensions tab and Disable them
Test access to Community menus again.
admin
Specialist II
Have you recently installed any Addons in Firefox? Can you please try disabling them?
We have just found an Addon called  "Privacy badger" to be causing this issue or any other pop-up blocker...
Ben
Senior Contributor I
Hi Karla,
I am using Firefox too and it works good. However, I am using ver. 34.0. A colleague just lately complained that he faced a lot of troubles in entering sites with Firefox, including local banks sites, but it happened after he upgraded to new Firefox version, so I keep working with ver. 34. Ole is working with ver. 37, maybe your development team know something about the late changes they did in Firefox
