Hello CW Team,
I was visiting a customer today has just downloaded and installed CodeWarrior 10.6 for MCU. We are using the TWR-KL25Z48M. We have downloaded kl25_sc_rev10 and we are using the bare metal CW platinum project. I have run the identical software on my laptop (mine was sitting next to the customer's) and I have perfect results. The problem we see on his at build time is
**** Build of configuration FLASH for project platinum ****
"C:\\Freescale\\CW MCU v10.6.4\\gnu\\bin\\mingw32-make" -j16 all
mingw32-make: *** No rule to make
target `C:/Users/b18357/Desktop/Leupold/kl25_sc_rev10/klxx-sc-baremetal/src/projects/platinum/platinum.c',needed by `project/platinum.o'. Stop.
I have not seen this error before. Can anyone suggest what causes this on one laptop and not another? Both are running Win7-64 SP1.
I then created a simple LED blinky program with PEx. This builds and runs on my laptop. It builds properly on my customer's computer however, when starting the debugger, it throws this error:
We downloaded the P&E drivers from their website today and installed them. I am not sure if these problems are related.
I was at the keyboard with both my laptop and the customer's computer so the customer didn't do something wrong; it's all me.
I do have one hint, at least for the second problem. The customer's computer has a previous installation of Atmel's tools, which also uses OpenSDA. I'm wondering if we have some conflicting .dll files installed.
I appreciate any help that you can provide!
Jim
Hi Jim,
the P&E dialog indicates that there indeed could be a driver problem. I wrote back some time an article about the different aspects and parts of USB drivers needed:
Fixing the USB Drivers | MCU on Eclipse
Maybe this helps identifying the problem?
Erich
