40 DIP Microcontroller
wärmekältetechn
Hi guys i'm looking for Motorola 40 DIP Microcontroller  1F15b  CTCTAB9831 need any halp .thanks
wärmekältetechn
ok thank you iggi i would try to copy the ic with GoodFET
wärmekältetechn
Hi iggi thank you i ask freescale but i don't get information (customer specific ic only customer can get information) over Motorola Logo can reading ECO STC-1.3 (eco german electronic manufacturer) 915.012 .
regards sascha
iggi
This seems to be some old HC05 or HC11 part. Don't you have the exact part number?
The characters you provided are maskset and LOT code which does not help much.
Still, HC05 and HC11 are obsolete products. You would need to look for the part at distributors.
iggi
wärmekältetechn
Hi iggi if it's 68000 family wath programming interface can i take to read program from ic?
iggi
If you've been told the device is customer specific, then i'm afraid i can't help you more.
It looks like you might want to hack the micro :-)
The 68000 series are MPUs which means no flash on chip. And also this series you want find in 40-pin DIP package.
