I am trying to use MQX with IAR. I am following the getting started guide included with MQX. However, after I select build all (section 2.1 on the Getting Started Guide), I get a bunch of errors that files cannot be found. I went through and started manually including the files in the "include additional directories" in the Preprocessor tab of the Compiler section of the options menu. See the listed I added below. I could get rid of some of them, but eventually ran into an error that said it couldn't find "comp.h", which a search of all the files reveals only in a Texas Instruments subfolder, so I don't think that's right. Regardless, it also seems to me like I shouldn't have to do this and I'm doing something wrong.
C:\Freescale\Freescale_MQX_4_1\mqx\source\include
C:\Freescale\Freescale_MQX_4_1\config\twrk40x256
C:\Freescale\Freescale_MQX_4_1\config\common
C:\Freescale\Freescale_MQX_4_1\mqx\source\psp\cortex_a
C:\Freescale\Freescale_MQX_4_1\mqx\source\psp\cortex_m
C:\Program Files\IAR Systems\Embedded Workbench 6.5\arm\inc\c
Some background, I am using EWARM version 6.5 I also have a bunch of other Embedded workbenches installed (a few kickstarts, an AVR version, a MSP430 version) I've had this screw up build paths before.
Anything I could try?
Could you please let me know which MQX version are you using??
Sol
Freescale MQX 4.1.1
Freescale MQX RTOS 4.1.1 was compiled and tested with IAR Embedded Workbench® for ARM® Version 7.10.3, could you please try installing this IAR version?
Sol
I don't have that kind of money to buy a new compiler just to test that. This is a poor answer and the reason I always regret signing up for forums.
