Where can I find a Digital Signal Processing library optimized for SPE for MPC8548 ?
estavesg
I am currently evaluating the performances in Signal Processing application of MPC8548 processor, and I am searching for a DSP library using the SPE engine.
Does anyone knows where I can find this ?
Thank you.
JW2026
Are these downloads still available? The freescale links don't work any more
trytohelp
FYI ... info provided by SR too.
I hope the following would be helpful.
AN3733 : Improving DSP Performance Using Efficient SPE Coding (including FIR example)
      http://cache.freescale.com/files/microcontrollers/doc/app_note/AN3733.pdf
MPC55xx SPE DSP Library 1
    http://cache.freescale.com/files/microcontrollers/software/app_software/code_examples/MPC55xx_SPE_DS...
MPC55xx SPE DSP Library 2 ()
PowerQUICC III Software Library replacing some libc functions by utilizing the SPE (memcpy, strlen...)
      http://cache.freescale.com/files/netcomm/software/libraries/libcfsl_e500.zip
Notice MPC55xx_SPE_DSP_Library_x.ZIP contains self extracted Windows *.exe archive.
Pascal
Freescale Technical Support
