I want to add Ethernet settings ( for example : static IP) to JB4.2. What should I do ?
I have made reference to theHow to Add Ethernet UI Support in ICS,
but those patches are made for JB4.0 , the direct use will be a lot of errors.
Hello Jiang,
In the same thread you mention, at the end of the very first post, the engineer mentions that they created an APK for 4.2 and 4.3. It is not a direct UI but an APK , though it works.
