I followed the procedures found here:
https://community.freescale.com/docs/DOC-1437
when I get to
./ltib –p libsocketcan.spec –f
I get an error:
RPM build errors:
Bad exit status from /home/madfsl/projects/linux/1008/ltib/tmp/rpm-tmp.4980 (%build)
Build time for libsocketcan: 16 seconds
Failed building libsocketcan
f_buildrpms() returned an error, exiting
traceback:
main:560
Started: Thu Jan 22 21:38:47 2015
Ended: Thu Jan 22 21:39:08 2015
Elapsed: 21 seconds
These packages failed to build:
libsocketcan
Build Failed
Exiting on error or interrupt
Part of the reason may be I can't get to this screen:
[*] Networking support --->
<*> CAN bus subsystem support --->
<*> Raw CAN Protocol (raw access with CAN-ID filtering)
<*> Broadcast Manager CAN Protocol (with content filtering)
CAN Device Drivers --->
<*> Virtual Local CAN Interface (vcan)
[*] CAN devices debugging messages
<*> Freescale FlexCAN
See it in the kernel but can't figure how to edit it.
Make .menuconfig works but it gets overwritten by ltib.
What's the best way to solve this?
Thanks in advance,
Scott
