Dear Sir or madam,
Hello.
My customer's system would like to original process the filter and the matrix operation by CPU power in i.MX6DL.
Is it possible to up the performance by the peripheral of imx6DL(NEON or GPU or IPU)?
If you have these sample, please give me it.
(OS: Linux or other)
Keita
Solved! Go to Solution.
Hi Keita
for examples one can look at :
AN4629 Fast Image Processing with i.MX 6 Series
Building OpenCV on ubuntu hardfloat rootfs for i.MX6Q
http://imxcv.blogspot.ru/2014/02/building-opencv-24x-for-freescales-imx6.html
Below description for Cortex-A8 (FFT) example, however I think similar procedure
can be used with Cortex-A9 too.
Fast Fourier Transform (FFT) example (benchmark) benchFFT
can be downloaded from http://www.fftw.org/benchfft/
To compile the benchmark use scratchbox cross compilation tool.
Copy the file to your scratchbox build directory
cp benchfft-3.1.tar.gz /scratchbox/users/jeff/home/jeff/home/.
Extract the package to your build directory in scratchbox
> tar xvzf benchfft-3.1.tar.gz
>cd benchfft-3.1Configure the build for the ARM Cortex-A8 with VFPv3 and NEON co-processors
> ./configure --host=i386 --target=arm --disable-serer CXXFLAGS="-O3 -march=armv7-a -mtune=cortex-a8 -mcpu=cortex-a8 -mfloat-abi=softfp -mfpu=neon -ftree-vectorize -fomit-frame-pointer -ffast-math" CFLAGS="-O3 -march=armv7-a -mtune=cortex-a8 -mcpu=cortex-a8 -mfloat-abi=softfp -mfpu=neon -ftree-vectorize -fomit-frame-pointer -ffast-math" Now compile
>make
Hi Igor,
Thank you for your reply.
I got the sample by using GPU.
Do you have sample steps by using IPU or NEON to process the filter and the matrix operation?
BR,
Keita
Hi Keita
I am afraid not.
