I see a note that this field has a write 0 to clear. Is this a type, the convention used up to this point in the resource manual is to use write 1 to clear.
Solved! Go to Solution.
Hello Larry:
That is not a typo, you have to write 0 to clear. This applies for both: [CF] and [ERR] bit fields.
I hope this clarifies.
Regards!,
Jorge Gonzalez
Hello Larry:
Regards!,
Jorge Gonzalez
