I am new bee of this communitiy. I enabled on motion detection, whenever the motion detected when i kept the device in same direction.
Please advice me what was the problem in my configuration
Siva J
I recommend you to take a look at the application note AN4070 “Motion and Freefall Detection Using the MMA8451, 2, 3Q”, in this document you will find the entire configuration required for the MMA8452 to properly detect motion with the embedded functions:
http://cache.freescale.com/files/sensors/doc/app_note/AN4070.pdf
Another document that can result helpful it’s the Application Note AN4076 “Data Manipulation and Basic Settings of the MMA8451, 2, 3Q”, this document includes all the basic and needed configuration for the MMA845x to start working on it: http://cache.freescale.com/files/sensors/doc/app_note/AN4076.pdf
This application note accompanies the MMA8451, 2, 3Q Driver Code:
http://cache.freescale.com/files/sensors/doc/app_note/AN4076SW.zip
Jose Reyes
I switch back to Portrait/landscape for this application is suitable for my projects
Thank you for great support, I was an vacation last 2 week,
