Dear community,
I am considering board hardware design.
I am checking the pin functions.
I would like to get a spreadsheet containing all pins.
Is there a spreadsheet somewhere that would help define the pinout for my design using the i.MX6Solo ?
The IOMUX tool can export a csv file, however the csv file does not include all NC and GND pins.
It is hard to use the csv file for a pin check.
Koichi Sakagami
Solved! Go to Solution.
Hi koichi
you can obtain it entering support ticket.
Hi koichi
Dear igor san,
Thank you for your reply.
I will enter the support ticket.
Koichi Sakagami
