I created a new board definition file based on the K64 FRDM. I deselect all examples and select only IAR as the IDE. At this point there is no way to save this information. If I close and reopen the application or the file everything is selected again. Not a huge problem but it seems like an oversight.
MQX 4.1.1
Kenny
Solved! Go to Solution.
Thank you for your suggestion.
I agree that it will be nice and implementation should not be difficult.
I suggested this improvement to responsible designer.
I guess that it will be implemented in next versions.
RadekS
RadekS
