The pins necessary for the minimal BDM header for use with the P&E wiggler are:
VDD
GND
ALLPST (connected to all four PST[3:0] pins on the P&E BDM interface)
PSTCLK
DSI
DSO
DSCLK
/RSTI
/BKPT
These configurations won't allow you to do trace functionality, but in terms of just standard debugging, this is the bare minimum you need.
I recently did a board layout where I used these 9 signals and /RSTO (though /RSTO wasn't necessary), created a little interface between my board and the standard 26 pin BDM interface from P&E, and everything worked perfectly.
Hope this helps.
mpeters
Message Edited by mpeters on
2007-09-04 04:58 PM
