I can’t send flash file to target using CW for MCU v10.2
johanforssen
I can’t send flash file to target, K10 (using CW for MCU v10.2, and a P&E multilink device). I can do exactly the same on my old computer, but not with my new one. I get the errormessage  “Error:  Couldn't stop the target.  Can't stop the target.
An error occurred while trying to write memory. The Debugger is not connected to the P&E device(ARM GDI Protocol Adapter)
Any ideas?
ZhangJennie
hi Johan.
please try below suggestion:
1. remove .metadata folder in your current workspace, then restart CW10 test your project again.
2. CW10.2 is very old, please try CW10.6 instead.
https://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=CW-MCU10&tid=CWH
please note: CW10.6 and CW10.2 can't share the same workspace.
this answer is for you. if it helps, please click on "correct answer" button. thanks!
ZhangJun
