I just bought FRDM-KL05Z, I have some doubt, I would like to use P&E to debug my code in this board, should I make any changes on board and connect to SDA ( J3) or just connecting the P&E should it works?
Solved! Go to Solution.
Hello Jose:
Not sure I fully understood your question. With P&E you mean an external tool such as a Universal Multilink? Because the on-board OpenSDA interface is also P&E.
In case you want to use an external debugging probe, I do not think you need any changes. Just plug the cable to J1 (*NOT J3*, that is for the OpenSDA K20).
Hope this helps.
Jorge Gonzalez
I had a problem with the configuration now is working well.
Hello Jose:
Hope this helps.
Jorge Gonzalez
Hi Jorge,
I tried to debug using J1 but nothing happen with it, I can't follow step by step my code. Any suggestion?
Jose
Hi Jorge,
Thanks for your answer.
Yes I mean Universal Multilink, I want to debug my programs in this board. I tought that I should connect the debugger to J3 instead of J1.
Jose
