I'm sorry, but currently there's not possible to disable the Noise Error interrupt. The only possibility is to disable a generation of the module (using the pop-up menu of the bean) and modify the code manually.
Anyway, I recommend to check if your signals have correct levels and timing, because there probably is some reason for invoking this error interrupt....
best regards
Petr Hradsky
Processor Expert Support Team
UNIS
