trying to RS485 example on k60 tower kit having some issue in fread
vallinaths
using the rs485 example code
void rs485_read_task
      uint_32 initial_data
   MQX_FILE_PTR rs485_dev = NULL;
   char  data_buffer[256];
   rs485_dev  = fopen( RS485_CHANNEL, NULL );
   if( rs485_dev == NULL )
      /* device could not be opened */
      _task_block();
   /* wait for data */
   fread(data_buffer, 1, 18, rs485_dev);
   while(1)
    printf("\n - Buffer_DAta              = %s Hz", &data_buffer);
The write task is printing the "RS485 example " in the serial terminal ,so write routine is working sine  , but the read task is not reading the character typed on serial terminal . if anybody has tried this program please support anything to be modified .
chandrasekarkan
      As you are trying to read 18 bytes in the fread call, it will block the task until all 18 bytes are received in the buffer.
Try reading byte by byte..
