Dear forum members,
We are facing LAN trouble now. We are using Vybrid VF5 chip and Timesys Linux(3.0) on our prototype.We think the trouble relates to Vybrid errata e6358. The symptom is as follows:
(Symptom)
(Condition)
We think this issue is related to the Vybrid errata e6358, “ENET: Write to Transmit Descriptor Active Register (ENET_TDAR) is ignored”. We made a patch to avoid that errata (the patch is attached to this message), then the trouble does not occur after the modification.
We are not so familiar with both linux driver and Vybrid so please give us the comment whether our patch is designed appropriately.
Makoto Katsukura
Referense:
Vybrid Errata ( Vybrid 1N02G )
http://cache.freescale.com/files/32bit/doc/errata/VYBRID_1N02G.pdf
Original Attachment has been moved to: 20131114_fec.patch.zip
Solved! Go to Solution.
Hello Katsukura-san,
Thank you for providing a description of the problem and the attached patch. We will review this submission, and following a successful review will add the patch to the current Vybrid kernel source tree. I will let you know when we have completed this, or if we have any additional questions.
Timesys Support
Timesys Support
timesyssupport can you help to check this case?
