Currently, with CW 10.5 and a Processor Expert with MQX-Lite project, I have a few tasks defined. The only thing regarding tasks that can be changed via the GUI is the number of tasks. When the code is generated, a file, task_template_list.c is created. It contains the task priorities, stack sizes, name, etc. The file comments states to not modify this file. So, how do I do make any settings from Processor Expert in CW? Also, I have Expert mode enabled, but this doesn't help.
Hi Paul,
check the MQX Lite Real Time Operating System User Guide.
You can find in CodeWarrior IDE -> Help -> Documentation -> Common Manuals
Regards Petr
