When I configure and build the rootfs using LTIB in IMX6Q platform, I enabled wpa_supplicant during configuration. however, the wpa_supplicant.conf file couldn't be found in rootfs. Without this file I cannot run wpa_supplicant for wlan0. Can any one help a little?
Thanks advance,
Solved! Go to Solution.
please try to find the wpa_supplicant.conf example from google.
