debug codewarrior就出现下面这个错误,请问怎么回事
Error : Unable to load CHC08.dll. Please check your HIWARE installation.
Error : Compile failed
求解答,要是有大神,直接联系我QQ644822736,方便帮助我,谢谢
It seems that the CodeWarrior installation is corrupted. chc08.dll should locates under \prog subfolder. What's the CodeWarrior version you are using, To get it, please: 1)Start the IDE and click on Help | About Freescale(Metrowerks) CodeWarrior. 2)Click on Installed Products 3)Provide all info displayed. Or you can save them in a txt file. What's the OS on your PC? Is it 32bit, or 64bit system?
My os is window8 32bit
the information you need as follows:
Installed Products:
CodeWarrior Development Studio for Microcontrollers V6.3, build 9279.
IDE Version: 5.9.0 Build 5292
Plugins: 78
ASINTPPC.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:43 628K
CmdIDE.exe 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:55 41K
IDE.exe 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:53 10.26M
IDENewDialog.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:44 201K
IDE_MFC60cw.dll 6.00.8665.0 6.0.8665.0 6.0.4.0 2009/8/27, 21:38 1.59M
IDE_MSL_DLL90_x86.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:36 296K
InstallHelperKeys.exe No Version Info 0.0.0.0 0.0.0.0 2005/3/22, 19:01 76K
lmgr11.dll No Version Info 0.0.0.0 0.0.0.0 2008/5/28, 17:05 1.42M
lmgr8c.dll No Version Info 0.0.0.0 0.0.0.0 2004/2/15, 19:02 832K
MWCore5_0.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:39 240K
MWRADUtils.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:44 260K
Mwregsvr.exe 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:45 36K
MWRegSvrWinApp.exe 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:45 36K
PluginLib.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:37 120K
PluginLib2.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:37 120K
PluginLib3.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:37 120K
PluginLib4.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:37 84K
PluginLib5.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:37 84K
PluginLib6.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:37 84K
SHW32.DLL 4.0.1.0 4.0.1.0 2000/2/11, 2:15 110K
sunvmhub.dll No Version Info 0.0.0.0 0.0.0.0 2002/1/29, 23:20 49K
tcl84t.dll 8.4.12 8.4.2.12 8.4.2.12 2006/9/25, 22:22 576K
utf8conversion.dll No Version Info 0.0.0.0 0.0.0.0 2008/5/22, 19:36 524K
xerces-2_2_0.dll 2, 2, 0 2.2.0.0 2.2.0.0 2009/8/27, 21:45 2.14M
Bin\plugins\com
CPPCodeCompletion.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:55 808K
DebugDatabase.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:59 324K
DebugRegisterMgr.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 22:00 116K
HC(S)08Wizard.dll 5.2.9279 5.2.0.9279 5.2.0.9279 2009/10/8, 0:30 960K
MWActivate.dll 5.9.0.5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:55 572K
PackAndGo.dll 1,0,0,9279 1.0.0.9279 1.0.0.9279 2009/10/8, 0:31 344K
PE_options.dll 1, 0, 0, 13 1.0.0.13 1.0.0.13 2005/8/8, 13:33 32K
PE_Plugin.dll 4.34.0.5219 4.34.0.5219 4.34.0.5219 2009/9/29, 14:16 7.50M
PE_prelink.dll 1, 0, 0, 4 1.0.0.4 1.0.0.4 2005/8/8, 13:34 95K
TipOfTheDay.dll 1,0,0,9279 1.0.0.9279 1.0.0.9279 2009/10/8, 0:30 64K
Bin\plugins
Bin\plugins\compiler
asm_mcf_elf.dll 6.0 build 38 5.0.0.38 5.0.0.38 2009/9/29, 6:22 290K
ELFImporter.dll 1.0 Build 0005 1.0.0.5 1.0.0.5 2009/9/29, 6:22 39K
hw_hc08_assembler.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 87K
hw_hc08_compiler.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 87K
hw_hc08_importer.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 87K
hw_rs08_assembler.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 87K
hw_rs08_compiler.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 87K
hw_rs08_importer.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 87K
MCFCCompiler.dll 6.0 build 38 6.0.0.38 6.0.0.38 2009/9/29, 6:20 2.11M
OsekCompiler.dll 2, 1, 2, 0 2.1.2.0 2.1.2.0 2006/9/12, 14:00 75K
PCLintCompiler.dll 1.5 1.5.0.5 1.5.0.5 2003/9/4, 16:58 80K
Bin\plugins\Editor
HC08_Coloring No Version Info 0.0.0.0 0.0.0.0 2007/4/16, 17:04 39K
MWE_Common_Coloring No Version Info 0.0.0.0 0.0.0.0 2004/12/29, 21:23 29K
RS08_Coloring No Version Info 0.0.0.0 0.0.0.0 2007/4/16, 17:04 78K
Bin\plugins\linker
BatchRunnerPostLinker.dll 2.0.0 Build 0006 2.0.0.6 2.0.0.6 2004/7/9, 14:01 40K
BatchRunnerPreLinker.dll 1.0.0 build 0002 1.0.0.2 1.0.0.2 2004/7/9, 14:01 42K
CRCPostLinker.dll 2.0 build 0 2.0.0.0 2.0.0.0 2009/9/29, 6:22 31K
ExternalBuildLinker.dll 5.9.0.5292 5.9.0.5292 5.9.0.5292 2009/8/27, 22:03 80K
hw_hc08_libmaker.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 92K
hw_hc08_linker.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 92K
hw_rs08_libmaker.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 92K
hw_rs08_linker.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 92K
MCFLinker.dll 6.0 build 38 6.0.0.38 6.0.0.38 2009/9/29, 6:20 397K
PCLintLinker.dll 1.5 1.5.0.5 1.5.0.5 2003/9/4, 16:58 84K
Bin\plugins\preference_panel
hw_hc08_libmaker_panel.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 89K
hw_hc08_linker_panel.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 89K
hw_rs08_assembler_panel.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 89K
hw_rs08_burner_panel.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 89K
hw_rs08_compiler_panel.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 89K
hw_rs08_importer_panel.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 89K
hw_rs08_libmaker_panel.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 89K
hw_rs08_linker_panel.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 89K
OsekPanel.dll 2, 1, 2, 0 2.1.2.0 2.1.2.0 2006/8/29, 18:11 70K
PAssemblerCF.dll 5, 0, 0, 1 5.0.0.1 5.0.0.1 2009/9/29, 6:22 198K
PBackEndCF.dll 6.0 build 38 6.0.0.38 6.0.0.38 2009/9/29, 6:22 77K
PBatchRunnerPostLinker.dll 2.0.0 Build 0004 2.0.0.4 2.0.0.4 2003/9/11, 23:31 39K
PBatchRunnerPreLinker.dll 1.0.0 build 0003 1.0.0.3 1.0.0.3 2003/9/11, 23:31 29K
PCFGlobalOptimizer.dll 6.0.0.38 3.0.3.38 3.0.3.38 2009/9/29, 6:22 33K
PCLintOptions.dll 1.5 1.5.0.5 1.5.0.5 2003/9/4, 16:58 41K
PCLintSettings.dll 1.5 1.5.0.5 1.5.0.5 2003/9/4, 16:58 82K
PCRCPostLinker.dll 2.0.0 Build 0 2.0.0.0 2.0.0.0 2009/9/29, 6:22 45K
PDebugx86Except.dll 5.9 Build 5292 5.8.0.0 5.8.0.0 2009/8/27, 22:04 64K
PDisassemblerELF.dll 1.2.0 Build 4 1.2.0.4 1.2.0.4 2009/9/29, 6:22 45K
PExternalBuild.dll 1.0.1.0 1.0.1.0 1.0.1.0 2009/8/27, 22:03 64K
PFrontEndC.dll 5.9 Engineering Build 5.8.0.0 5.8.0.0 2009/9/29, 6:22 68K
PLib.dll 5.9 Engineering Build 5.8.0.0 5.8.0.0 2009/9/29, 6:22 225K
PLinkerCF.dll 6.0 build 38 6.0.0.38 6.0.0.38 2009/9/29, 6:22 49K
pMWCVS.dll 1.3.0.5292 1.3.0.5292 1.3.0.5292 2009/8/27, 22:03 64K
pmwSourceSafe.dll 5.5.1.40704 5.5.1.40704 5.5.1.40704 2004/4/13, 17:47 29K
PPreprocessorC.dll 5.9 Engineering Build 5.8.0.0 5.8.0.0 2009/9/29, 6:22 72K
PProjectCF.dll 6.0 build 38 6.0.0.38 6.0.0.38 2009/9/29, 6:22 30K
PWarningC.dll 5.9 Engineering Build 5.8.0.0 5.8.0.0 2009/9/29, 6:22 68K
hw_hc08_assembler_panel.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 89K
hw_hc08_burner_panel.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 89K
hw_hc08_compiler_panel.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 89K
hw_hc08_importer_panel.dll 5.0.14.9279 5.0.14.9279 5.0.14.9279 2009/10/7, 13:46 89K
Bin\plugins\Support
CPlusSourceGen.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:53 272K
crcgen.exe No Version Info 0.0.0.0 0.0.0.0 2009/9/29, 6:22 140K
MWComBase.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:42 64K
MWComHelpers.DLL 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:40 460K
MWRadModel.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:44 572K
Bin\plugins\version_control
mwcvs.dll 1.3.0.5292 1.3.0.5292 1.3.0.5292 2009/8/27, 22:03 228K
mwSourceSafe.dll 1.0.3.716 1.0.3.716 1.0.3.716 2004/4/13, 17:47 137K
VCSClearCase.dll 1.1.2.1999 1.1.2.1999 1.1.2.1999 2004/9/29, 17:28 76K
Bin\resource
CPlusResources.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:53 24K
ExternalBuildResources.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 22:03 6K
IDEAuxiliaryResources.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:40 44K
IDEResources.dll 5.9.0 Build 5292 5.9.0.5292 5.9.0.5292 2009/8/27, 21:40 52K
For HC(S)08 product, the classic CodeWarrior v6.3 does not support Windows 8, nor Windows 7.
It supports Windows® 98 SE/2000/XP/Vista 32 bits. Below is the link for more details:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=CW-MICROCONTROLLERS
There is a completed workaround to install and use it on Windows 7 64-bit machine, please refer to the document below:
http://cache.freescale.com/files/soft_dev_tools/doc/app_note/AN3936.pdf
However there is a P&E driver issue. Customer must download the V10 from P&E web site too.
We recommend Eclipse CodeWarrior, the Eclipse version v10.4 support Windows 8. You can find more information about it and download it from: http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=CW-MCU10
