Flash write speed in K60
Cherukuri
I am using K60 with 121 pin. I am configuring my CPU clock to 96MHz and Flash clock to 24MHz. The thing that I would like to know is, Whats the flash write speed that we can achieve with this settings?
Please let me know the same.
Tags (4)
Hui_Ma
The Kinetis flash module contains its own internal 25MHz oscillator, that means whatever the Flash bus clock frequency frequency is, the Flash programming is run with 25MHz Flash module internal clock.
Customer could find Flash program speed data at datasheet chapter 6.4.1 Flash electrical specifications:
http://cache.freescale.com/files/microcontrollers/doc/data_sheet/K60P120M100SF2.pdf
Wish it helps.
Hui_Ma
Wish it helps.
