Dear All,
One of my customer wants to drive a bipolar step motor and maximun output current of 0.7A.
Customer has chosen MPC17531A but we found this series is not recommended for new designs and there is no replacement part also available.
Please advise if suitable part is available in freescale which can meet customer requirement.
Thanks in Advance
Mithun
Solved! Go to Solution.
Hi Mithun,
Then I would recommend considering the MC34933, it is also a dual H-bridge with an ambient operating temperature up to 85°C.
Tomas
Hi Tomas,
Thanks for your inputs, sorry I missed out to mention the temperature range customer need a part supporting up to -20 to 80deg, the parts mentioned above from you support upto 60deg.
Your suggestions are really valuable.
Thanks & Regards
Mithun
Hi Mithun,
Tomas
